Autore Topic: nuovo spp 6.5.2  (Letto 283 volte)
  • Post: 1.679
nuovo spp 6.5.2
« il: Giovedì, 13 Aprile 2017, 08:37:18 »
disponibile per il download
http://www.sigma-global.com/en/download/cameras/sigma-photo-pro/
Main Features
Ver.6.5.2
It has improved the noise reduction during the RAW development from the X3F files of dp Quattro series and sd Quattro series.
It has improved the processing speed when the GPU Acceleration Mode is activated in the environmental setting (based on the computer environment, the effect may vary).
It corrects the phenomenon that some operational errors occur in specific computer environments, when GPU Acceleration Mode is activated.
It corrects the phenomenon that depending on a computer environment, an error occurs during RAW development, when the GPU Acceleration Mode is activated and multiple images are selected.
* Since SIGMA Photo Pro ver. 6.5.0, it has changed the system requirements to OS ver. 10.9, 10.10, 10.11 and 10.12, and 3GB or higher RAM (8GB or more is recommended).
* For customers who cannot use the GPU Acceleration Mode, please refer to this webpage.
Ver.6.5.2
* Since SIGMA Photo Pro ver. 6.5.0, it has changed the system requirements to equivalent to Intel Core 2 Duo Processor or more (equivalent to Intel Core i series is recommended) and 3GB or higher RAM (8GB or more is recommended). In addition, it is not possible to use the functions of printing, slideshow and multiple displays of Review Windows in the 32bit OS system. To use these functions, please use SIGMA Photo Pro 6.4.1. Please download from here
  • Post: 734
Re:nuovo spp 6.5.2
« Risposta #1 il: Giovedì, 13 Aprile 2017, 12:20:24 »
Tutti interventi necessari, perchè l'accelerazione GPU era molto acerba con frequenti crash mentre la riduzione del rumore con il sensore Q aveva bisogno di una bella sistemata.
Molto bene, stasera testo
Offline Simone67
  • Post: 272
    • Rovetta
Re:nuovo spp 6.5.2
« Risposta #2 il: Giovedì, 13 Aprile 2017, 14:23:44 »
Finalmente niente crash con la 6200 dell'iMac 21,5" Retina 2015 ed anche ottime prestazioni.
  • Simone
Fujifilm X-10 / X-30
  • Post: 1.679
Re:nuovo spp 6.5.2
« Risposta #3 il: Giovedì, 13 Aprile 2017, 14:31:27 »
  • Post: 3.487
Re:nuovo spp 6.5.2
« Risposta #4 il: Giovedì, 13 Aprile 2017, 16:03:32 »
Provato al volo velocemente.
   1.Ottima riduzione rumore molto più aggressivo, specialmente nella meta destra confronto a prima che sembrava facesse niente.
   2. Ottima la modalità di selezionare la scheda video dedicata, prima mi sembra che lavorava solo con "lato" video integrato nel processore e di fatti adesso svillupando i raw della "quattro" mi sembra di svillupare i raw della SD15 con la versione 5.x , in pratica mi sembra che la velocità di elaborazione sia raddoppiata.
   3. E comparsa qualche altra voce nelle preferenze di spp che prima non c'era, per esempio "Settaggio Sigma Capture Pro cooperative" non l'ho provato perché SCP c'è l'ho solo sul tablet, appena posso prove vedere se una volta scattato ed importato da SCP si apre SPP.
Comunque secondo me questa terza opzione e fatta per lo più da usare in studio ma hanno fatto la ... "corazzata Potemkin" in fase di costruzione della SD4 perché non hanno messo la presa per alimentazione esterna della macchina e lavorare col PC collegato alla macchina, quest' ultima si ciuccia la batteria a vista d'occhio. :ohi: e devi star più a cambiar batterie che lavorare , a meno che non si prende una batteria con presa di alimentazione esterna fatte apposta per le Panasonic GH4
Offline sergiozh
  • Post: 430
  • DP2M
    • Svizzera
Re:nuovo spp 6.5.2
« Risposta #5 il: Giovedì, 13 Aprile 2017, 16:12:43 »
Nei commenti alle prove che fate sarebbe buono se comunicaste se siete sotto windows o mac.
  • Post: 3.487
Re:nuovo spp 6.5.2
« Risposta #6 il: Giovedì, 13 Aprile 2017, 16:13:31 »
Sotto winzoz , scusa
  • Post: 6.624
Re:nuovo spp 6.5.2
« Risposta #7 il: Giovedì, 13 Aprile 2017, 19:20:05 »
Il primo screenshot mostra l'effetto del NR di luminanza sul valore centrale del nuovo SPP, che invece nella precedente versione (sempre al centro) ha l'aspetto del secondo allegato.... in pratica, non si può più ridurre il NR come in precedenza.
  • Post: 3.487
Re:nuovo spp 6.5.2
« Risposta #8 il: Venerdì, 14 Aprile 2017, 01:20:45 »
Oggi ho scoperto che se si apre SPP con anteprima del immagine sulla finestra principale e si fa doppio clic sul anteprima questa si apre al 100%  :si:
