Autore Topic: Lenti piatte, ovvero metalenti.....  (Letto 427 volte)
Offline Lorenzo
  • Post: 1.259
    • Trento
« il: Sabato, 25 Novembre 2017, 12:10:33 »
Vi segnalo questo interessantissimo link ad una nuova tecnologia: lenti piatte....  ???
https://www.seas.harvard.edu/news/2016/06/metalens-works-in-visible-spectrum-sees-smaller-than-wavelength-of-light
Sono al TEDx Trento ed ho appena sentito il fisico Capasso in videoconferenza. Sono basito...  :wow:
Poi faccio pace...
  • Post: 3.529
Re:Lenti piatte, ovvero metalenti.....
« Risposta #1 il: Sabato, 25 Novembre 2017, 13:13:03 »
Incuriosito sono andato in cerca di ulteriori informazioni e ho trovato questo ducumento
https://www.seas.harvard.edu/capasso/wp-content/uploads/publications/jstqe_visible-wavelength-planar-metalenses(2).pdf
li ho dato una spulciata veloce ma da quanto scritto in coda alla pagina 5... non so l'efficienza (il "rendimento" per cosi dire) delle classiche lenti ma da quanto lego ... ne dovrà passare di acqua sotto i ponti prima di vederle sul mercato
The latter was measured as the optical power passing through
a circular aperture (aluminum on glass) with the same diameter
as the metalenses. The focal spots are measured and shown
in Fig. 4(b)–(d). Highly symmetric focal spots were achieved
for all three metalenses. This is more clearly evidenced by the
intensity cuts along the focal spots, as shown in Fig. 4(e)–(g).
Most importantly, the obtained focal spot sizes are close to the
ideal diffraction-limited values. This is an essential factor for
many applications beyond microscopy such as laser fabrication/lithography
and machine vision where the focal spot size
defines the achievable resolution. It also sets the limit for the
maximum imaging resolution when these metalenses are used
for imaging purposes. Full-width at half-maxima (FWHM) of
450, 375, and 280 nm, with corresponding focusing efficiencies
of 66%, 73% and 86% were measured for these metalenses at
their design wavelengths of 660, 532 and 405 nm, respectively.
li hanno testato solo con laser a specifiche lunghezze d'onda (luce monocromatica) e l'efficienza non e uniforme su tutti 3 colori , di fatti anche dalle immagini presenti nelle pagine 4 e 9-10 si nota un notevole calo sui rossi , come renderanno in realtà su tutto lo spettro visibile a questo punto  :-\
Offline Lorenzo
  • Post: 1.259
    • Trento
« Risposta #2 il: Sabato, 25 Novembre 2017, 13:55:39 »
Non ho avuto tempo di leggere, ma il Prof ha detto che qualche settimana fa hanno ottenuto una immagine a fuoco con tutto lo spettro! O così ho capito io. E hanno fondato una "startap"-> Metalenz.
SIGMA, comprala!!!  :gh:
Poi faccio pace...
